news NEW Zetor 6170 "Series 6" (former Forterra/Crystal) 130-171 hp
On Zeme Zivitelka fair, Ceske Budejovice, CZ, Zetor has announced to introduce a new tractor model with 120-171hp. Zetor North America says it is the new Forterra , available from third quarter of 2024. What is clear is that it has a completely new cab, but we will follow what details will be publicized in the next week.
As can be seen, it has a steel sickle above the mudguard, like the Proxima.
This is because the cabs have been placed higher on Crystal and Forterra to improve operator visibility, which left a bigger gap between tire and mudguard at the back, with the previous cab.
Possibly this allows for more room above the wheels to install the more ergonomic hydraulic control levers of the Proxima in the HSX too.
Other noticeable change is the doors are bigger, the B pillar of the cab is moved roughly 20cm back, and the door hinges are different.
Will this new Forterra have a Deutz TCD 4.1 up to 171hp ? Or will the Forterra be available in both 4 and 6 cylinder like Deutz-Fahr ? We will report as soon as more news comes out...
Because of the current price level of the Forterra, ergonomic or technical flaws are not permissible for Zetor, even at basic spec tractors they require to have their ergonomics (placement and logic of the controls, feel, noise, vibration, harshness) spic and span...
Spotted by Forum member twan hag
This message edited with new information 30-08 9:45pm
Interior definately looks good too.
According to the sticker, front 3pt lift on the joystick, plus one extra remote (to lift the rear mower) which is perfect.
Buttons on the joystick for a 3rd function in case of a frontloader?
More electrohydraulic functions are not needed, but four additional mechanical spools for a total of 6 (plus frontlift) are quite a lot. Two mechanical spools is enough in base spec.
It does need more mounting rail for control terminals of e.g. the slurry tanker, the tire inflation system controller, etcetera.
My friend very likes the Puma mountng bracket, it is fast to install terminals.
Look at 2:35 how full the monitor rack is with a Rapide 660 behind it:
View: https://youtu.be/5Xyr17rShRI?si=tfiPNuF7pqDn5Pvz
