oil leaking out were brakes are on a 6718
thomas
thomas
oil starting to drip out were brakes connect to tractor
i take it there is a seal there , is it a big job to fix
thanks
To replace the seals is the same job as replacing the brakes, you have to take out the portal and there is two seals, one in difhouse that goes on a race on the brakedrum and one on the shaft inside the brakedrum.
i mean were the brake pedals go into side of the tractor
thanks
thanks
You mean on the pedal pivot shaft: drain the geabox oil, loosen pedal (circlip ??) push pivot rod back and pry the seal out. very easy.
thanks for that. thought it was gonna be a big job
