Hello everybody!
I have an issue with my transmission in 6211. The transmission is quiet untill it warms up, than it develops quite a nasty rattling sound which can be heard in the video. It gets even worse when in using the engine brake for example when im hauling slurry. The whole tractor starts to shake, feels like a bearing has gone out completely. I drained the trans oil, checked the magnet on the drain plug and there was limited ammount of shavings which i believe is from gears grinding when shifting. Could it be a broken tooth off a gear or something way more serious? Tractor has about 4200hrs. Thanks for recommendations.
View: https://youtu.be/B79uBGvp378?si=cBbrvBP3JA3sbHX7
