Hello.
Well done. For lights you rotate the key. There are three positions. When the tractor is parked always pull the key up into a power off position. Also check the front hubs have oil. Checked from the outside of the rim. Large drain plug, small check plug.
Thanks for the reply
I guess I'm up for a new key setup, having trouble keeping power to the dash, you have to hold it in a certain position to start and keep the gauges on, if you let go of it everything stops working
Sorry for all the questions, but what do the 4 little lights in the tachometer do? I understand greens indicators, blue is high beam, but what do the other ones do? There's a red one but unsure what its for
You know I don't know. Perhaps alternator warning light. The dash on mine is different to the one in my handbook . The handbrake had a light. They always go off and it's never arisen. My tractor is 1980, yours is a later model. The date is on the makers plates, one for the factory and the other for Zetor Australia.
Thanks mate, it's an 85 model, stock number 12145-53 so it's pretty early, I wired past the key and put a switch in for the ignition, that red light has me wondering, wouldn't think it would be a oil pressure light, I'd say charge, it has some sort of vacuum gauge what does that show?
