question Wich order does piston rings go on Zetor 5511?
Bondenesn
Gotland, Sweden
Bengt Erik Eriksson
Zetor 3011 -63, Zetor 5511 -71
previous: Zetor 8011 -76. Zetor 10045 -83
In wich order does piston rings go on 5511?
There is three different piston rings and two oil scraper rings in my kits.
One uncoloured ring, one black ring with a outer chamfer groove, and one black plain ring, how arethey supposed to sit?
Answering myself. After all i hve the old pidtons to compare with :wisseling:
from top:
- uncoloured,
- then black.
- Nr 3 goes the black one with the schamfer groove facing downwards.
- Ant at last (bottom) the twoo oilscrapers..
Have a good day.
So far, that's correct.
Also, always check the piston ring gap beforehand, install with the labeled ("top") side of the rings facing up, and then arrange the piston rings so that their gaps never overlap.
Then install using a piston ring clamp and LOTS of oil...
