question Zetor 12245 upgrade seat and install air conditioning and can suspension
gregkon
Greece
Greg
Zetor 12245 1994
Hello everyone one! I have a zetor 12245 I want to install air condition system does anyone can help me what is the best vfm. System kit ? From Europe or AliExpress or zetor system . And I want to install Grammer seat what type of those is the same height? Iam interesting to install diy suspension cab system any opinions?
Hello Greg. Grammer make a lovely non air seat that was fitted in the last of the 10641 range. I would fit one of those seats in any of my tractors, if I was fitting a new one again.
Can you tell me, what you mean by vfm system kit?
I want to install a/C system but not too expensive over 400-700 euros plus install I found GRAMMER Maximo Comfort Plus MSG 95A/731 I read good reviews on this site .
And I am interested to make modifications to install air or spring can suspension any opinions?
I see some 12245 install universal a/C kit that's I am asking.. at Greece summer has more than 40 degrees hahaha
Maybe someone else on here can answer you.
In Ireland, we only need a/c on a tractor the odd day in summer.
One idea is to install a bigger alternator, and to fix a set like this
on the roof (the compressor needs AMPS, so tou need heavy cables. But it's easier that plumbing i think?).
Here is a design picture (from a finnish web forum), the plate is the roof hatch.
Thanks but I don't want at the roof one zetor has aftermarket kit but I dot now we're buy it ... We're can I find original parts for zetor 12245 ? At cz or Slovakia? Original for hydraulics etc not aftermarket
You can just use the Google search by "Zetor xxx" (xxx will be the spare parts number you need) to find your needed parts.
You can then only ask if they ship also to Greece... Signs for original pars are the one signed with "CZ" or "SK" or "Zetor original". Or ask your lokal Zetor dealer.
Local dealer sell junk parts no quality
The local official Zetor dealer? :eek:
Well, you can never be 100% safe from bad parts, it can happen to you at any dealer, but it shouldn't be the rule. ;)
Try Nekvinda (CZ) or Marting (SK) - both long-established suppliers, quality is usually OK.
Ask him directly via WhatsApp or mail - If original parts existing, he can help you. Same at the other one. :)
120 amp alternator ???
The original one 83.355.951 have 14 V 55 A - you have to replace some wiring if you tune up it to 120 A alternator.
Maybe something like that:
But take care and take a look at measure.
I have a 100 A alternator (Alanko 44168:cool: in my Zetor 5011 - with thicker cables and some more changes.
Limaumbau_11.jpg Limaumbau_10.jpg Limaumbau_06.jpg Limaumbau_neue_10.jpg Limaumbau_neue_11.jpg
I had to replace the pulley with one from Zetor and slightly adjust the mount. Then I also had to install reinforced power cables to match the increased power and a larger battery (195 Ah instead of the original 140 Ah).
Also heplfull: ;)
???`sorry I dont understand what you mean.
Can you explain it a little bit more?
