zetor 3045 constant velocity joint needed!!
to be honest im not sure wot a cv joint is> we just call them uj joints. if you mean the ones in the hubs of the front axle you will have a hell of a job to try and get one! if you mean the joints on the prop/driveshaft these are available but are somethin silly like 300 a side.
god luck
matthew
Matthew
A CV joint is a " constant velocity" joint as found on the front axle of front wheel drive cars.
Tractors usually have double UJ's ( Universal joints) on the front axles because they are far stronger size for size, but even a double UJ does not revolve smoothly during each revolution of the axle when the wheel is not straight ahead. This doesn't matter with a relatively slow turning axle in a tractor, but on a car there would be unacceptable vibration when turning at any speed, hence the fitting of CV joints. Roadless tractors had CV joints in their front axles,because they were sourced from ex-military trucks initially, but they had to have torque limiting slip clutches in the front prop shafts to prevent overloading .
Dave
