Gents, I just had my clutch replaced in my tractor. When I picked it up the clutch pedal was very hard to press. Also, the PTO hand clutch is very hard to pull. The clutch for the transmission seems to be doing its job. I have not had the opportunity to try the PTO as it was late when I got it home. Could it be the springs in the New Clutch are that much stronger? I replaced the clutch with a DSF-79010011-KIT Zetor 12.25" or 310mm Double Clutch Kit. New Disk, Release bearing pressure plate assy. bearing and PTO Release bearing from TPD. I am the original owner and don't recall it being that difficult to press when new. Any suggestions would be greatly appreciated.
