Zetor 3320 making loud noice
ftr
FTR
I have an older Zetor 3320 (a 96 I think), the other day when I started it up it started making a loud knocking noise, not sure what it is any help with it would be great. I think it is the oil pump not working right but have had a hard time finding it on the engine, any ideas where it is?
It is good on water, has never ran low. No the lights on the dash do not work, never did figure out out to get them to work. If it is a bearing that engine is toast, would have to solve how to rebuild it, and there is no books on how to do that.
well found out the problem. The third piston on the cam shaft was loose. Ok so I found this out the hard way. Yep, the rod went through the side of the block. So now I am on the look out for a new block if anyone knows where I can find one that would be great.
