Zetor 3320 VERY new Newbie How do I start this thing?
rltmp
RLTMP
First of all, I apologize for my total ignorance of tractors ..... but I want to learn!!!!
I just received a Zetor model 3320, around 1985, and I cant figure out how to start it.
I found the fuel primer, the start button by the wheel, has a good battery, everything is in neutral, it wont turn over
What am I missing?
Thanks for your time!
A couple other things... push the throttle lever all the way up when you are starting. After it starts, pull the lever down to get the engine speed you want. To stop it, pull the throttle lever all the way down.
I had all the same questions on my 3340!
Thanks guys, going out to the property this evening and will try again!
My 5340 needs to have the clutch pushed all the way in and the PTO clutch lever(yellow handle) disengaged(pulled up) as well. The switch under the PTO clutch lever occasionaly sticks so I have to poke at it it to get it to pop up.
