Zetor 3511 oil problem?
zetormatic3511
Zetormatic-3511
Hi all.
Iv got hydraulic fluid or gearbox oil coming out just under my seat and also out of the pto shaft??Its of a white ish colour...
Any ideas?
The leak under the seat is probably the pipe for the spool connection. The PTO shaft probably just needs a seal if it feels tight. The oil is whiteish because water has got in and mixed with it.
The water mixed oil luses some off its lubricashen abiliti and this often coses seals on runing shafts to bracke down.
The oil is coming from between two pieces of metal..I think where the hydraulic pump is bolted to the gearbox.
Thanks for the quick replies but any ideas on a quick fix?
Watt two pieses of metall? Inside the cower on topp of backakselhouse is the hydrolicn ram and valveblock, under the backend is a round plate vhit the pump, leak from any of thise you have to unbolt the part and replace the gasket and a cople of o-rings for the hydrolic pipe.
