Hello.
Hi guys another question. I have pulled apart the front axle on my 5545 and found that the universal joints are pretty much destroyed just wondering what other models of zetor front axles will fit
Thanks in advance
Most of the parts you require for a rebuild, are available from Barlows zetor . Click onto their parts list, then axle. Move down the list and you will find a photo of the parts listed for 3045 and 3545. The part numbers appear the same as for 5745, which used the 5545 axle. They do not show the bearing caps, but its possible that drive shaft uj's use the same bearing caps, if your lucky.
BENO CZ also have parts in stock, although not the cross. On their E Shop, type in part number 953210, which will bring up photo of the carrier. Move the mouse onto the red info above the photo, the panel will turn green, click mouse and info will expand to include photos of the other parts including the cross shaft etc.
Regards, Matt
