Z
Zigzag
Guest
Hi, I have a Zetor 6045, I can not get it started I think it is a fuel problem because I have fuel up to the injectors but not traveling upthe injector lines to the top on the engine. I took the lines off and the part where the lines attach to the engine is not allowing the fuel to go through, there is a spring in there that is suppose to lift up to allow the fuel to travel through. with teh part off the fuel travels no problem but when I put it back on the spring pushes the little valve back down stopping the fuel.
Any suggestions
Any suggestions
