My 6045 had a bad leak at the 4wd shaft on the bottom of the gearbox. I drained the oil and replaced the seal and have filled this up so it is showing on the dipstick.
The 3pt works and the arms are raising and lowering. When I push the hydraulic control lever fully forward (to the right of the seat) I can hear what I assume is the pump engaging and when I pull it all the way back it does not make a sound. I thought it was dual action and expected to hear the pump in both full forward and full back positions.
I have the pto / hydraulic lever in the fully forward position (which i believe is hydraulic only) although the when I hop out of cab I Can see the PTO shaft running very slowly even when this position is selected.
My FEL has one line which connects to one of the quick connects at the back of the of the tractor and another line which is adapted to fit to the fill point / dipstick inside the cabin. It has a set of levers fitted which are to the right of the steering wheel.
When i pull any of these levers nothing seems to happen with the hydraulics going to the FEL. I am wondering if there is another option to activate the rear hydraulics or do I need to prime the lines going to FEL or is there something else?
Sorry for the long post and thanks in advance for the assistance.
