I need help wiring the electric fuel pump.
I wired the hot wire to the red wire in the ignition switch. When I did this the pump does not work until I insert the key(which is good thing). The problem I run into is when I push the button to start the tractor something is tripped, which cuts the power.
I wait a few minutes insert the key can hear the pump work, I push the button and again it cuts the power.
I pulled the ignition switch down from the dash board to wire pump.
I don't know what is causing the power to be tripped when I push the starter button.
Any suggestions would be welcomed.
