Zetor 6245 Question: Uninstalling a Fuel Lifter Pump
brunor
BrunoR
Hi, I'm new to the forum and really hoping someone might have a suggestion for how to access the second bolt on my Zetor 6245 '93 Fuel lift pump I'm trying to replace. The bolt is currently hidden by the fuel injector pump making difficult to access. I'm trying not to remove the fuel injector pump, if possible to swap out the fuel lift pump. The heart of the issue I'm trying to address is the tractor doesn't get fuel to the injector pump. Any guidance on how to access this second bolt would be greatly appreciated or other things I should consider. Searching the forum didn't turn up anything so I hope I'm not asking something that already been covered. Thanks- Ron
It is difficult but not impossible. I use a small swivel socket wrench. When the new one should be installed it is tricky as the pump is springloaded. Use a lever to keep it in place while you tighten the outer bolt. Small fingers is a benefit.
Hazze
