Zetor 6945 block heater
hultetlivese
Jonas P
Hi everybody, i plan to buy block heater 6901-1730 for my zetor 6945. Problem is that i can't find where the plug in for the block heater is. The only one i see is in two in front of the top on the first cylinder, shall i put it there?
Number is 940201 i believe. And it goes in a frost plug on the left side of 4th cylinder.
I have no frost plug on the left side, but on the right side under the forth cylinder there is a rectangular hatch attached with one bolt. Do you know what that is?
i think you mean the camshaft covers...
Thats where it goes. In that rectangle block should be a round spot. Thats where mine is.
Sorry, i read your post too quick. Left side toward the top of the block by the 4th cyl is a rectangle block cast into the engine block. In there is where my block heater goes. What you are talking about is what Renze said
