- Jun 22, 2017
- 6
- Ben_M
Dear all,
I've trawled through the search feature on this forum but havn't found the answer to this so here goes...
I have recently aquired a zetor 7045 that's not starting due to being starved of fuel . I've fitted a new hand primer pump as the old one was suspect. I've successfully primed the two fuel filters and then the two bleed screws (10mm with screwdriver slot) on the fuel pump to either side of the four metal pipes going to the injectors.
So far, so good. I get fantastic, strong, air free fuel delivery to this point and there are no bubbles visable in the glass bowl.
Beyond this point i am miffed. I lossened the metal fixing on the 1st injector and no fuel arrived after 15mins of hand priming/pumping. I then lossened all four connections to the injectors at the fuel pump end and pumped - and got absolutely nothing. When everything is reattached, the only place where fuel comes through (intermitently) is the return pipe from no4 cylinder.
Is my fuel pump knackered? I notice the bolts stamped "oil" and the one with dipstick (nearest cab) is dry. Could this be an issue? How is this pump oiled, does it have it's own resevoir? If it's been low for a while will it screw the pump up so bad that no fuel can get through?
Thank you very much for your time reading this and I hope someone can help me.
I will try and post pictures.
https://www.imageupload.co.uk/image/DBBl
https://www.imageupload.co.uk/image/DBBr
The tractor did have starting problems at the farm it came from, but then i got it running approx 1 month ago. Then the lorry arrived to collect it last week and it wouldn't start, it got dragged around by a big new massey to bump start but that didn't work.
Thank you.
Ben
Thank you.
Ben
