Zetor 7745 Clutch and release bearing
fox
David Lindsay
I changed out my master clutch cyl and clutch slave cyl. Now when I activate the clutch, the slave cyl piston moves out more and more with each push of the clutch until it leaks and then the cyl cannot retract until we bleed it. Is there a problem with my clutch lever? Any ideas. Thx.
clutch fingers an or release bearing i worn out. most likely from operators riding With foot bearly on pedal. you can inspect it through the Hatch on left side of bellhousing.
Thank you. I bought this tractor in 2007 and it has been good to me. What is involved in changing bearing.
I also read on the forum that if the release bearing does not get a bit of oil now and then they won't move, but too much oil is a worse problem......any experiences.
have had a 7745 and it was a good tractor. the oil on the bearing option was taken away because most People put in too much. its not a problem you need to worry about. have not had any sticking bearings on tractors thats used on a regular basis. to change bearing and fingers you need to split tractor between engine and clutch house.
