Zetor fuel problem
wfletcher
Warren Fletcher
I have s 5211 that has been difficult to start. During the investigation of the problem we discovered that we are only getting fuel to the rear cylinder. The front two are not getting fuel at all. Tractor has been very useful as it is equipped with a front loader but has not been used as much lately. Not sure if there is something stuck or broken in the injector pump but cant figure out why Im not getting fuel to the front two cylinders. Any help would be greatly appreciated
You could take off the pipes between the pump and the injectors and see the pipes aren't just blocked by corrosion, other than that you could turn it over without the pipes on to see if the diesel is coming out, then you'll be needing to get the pump off for reconditioning.
