When I push switch it lights up but doesnt disengage when I push down brake pedal. If I hold down switch and depress brake pedal light on switch goes off but still wont disengage DIFFERENTIAL
Is the control mechanical or is there a solenoid I can check ?
Regards
Regards
It has a solenoid under the floor. There’s a plastic cap on the exhaust union. This union can block as it has a filter gauze in it. Check the piston on the r/h side of the gearbox moves freely.
