question Zetor Proxima differential wont unlock - what can I do?
cyrildarcy
Ireland
Cyril
Zetor10541 Proxima plus
My differential wont appear to unlock while I depress brake on my Proxima plus 10541 Any suiggestions
Any
I think it sound like an electrical problem.
When I push switch it lights up but doesnt disengage when I push down brake pedal. If I hold down switch and depress brake pedal light on switch goes off but still wont disengage DIFFERENTIAL
Is the control mechanical or is there a solenoid I can check ?
Regards
Cyril
Regards
Cyril
If the differential lock is activated with compressed air maybe there is a problem in the air sistem? Do you have enough pressure in the sistem?
It has a solenoid under the floor. There’s a plastic cap on the exhaust union. This union can block as it has a filter gauze in it. Check the piston on the r/h side of the gearbox moves freely.
