I've removed both portals from a 6011 (UR1) with drum brakes for a brake overhaul........
Just cleaning up the parts and noticed that the handbrake adjustment rod/fork has a slight crank (bend) in it near the spring..... Unfortunately I didn't see this with the assembly in position and now I don't have any side to reference..... The workshop manual diagram doesn't show the crank (bend) in the forked rod.
Which direction does the rod go in? Is the crank towards the bottom or the top of the housing?
Many thanks if you can help !
