Hello, I recently picked up a 3340 and it started and ran great everyday until 4 days in, after a rain. Now it does not want to start/turn over. I get an occasional click at the starter but nothing more with standard starting. I can hookup cables to my solenoid and get it to turn over but only a few times, where as the first time I started it (battery was almost dead) I was able to start it with cables like normal (turned over easy).
I am probably gong to pull the starter and solenoid to bench test but I think my issue is in the wiring. THERE ARE A LOT OF WIRES, LOL.
Can anyone advise a basic process here to eliminate what could be causing the key and button to have almost no effect on starting? Again, randomly I'll get one click at the starter and nothing more. It has been a few days now without rain and still won't start.
Symptoms as of now:
1) lights don't work when I turn the key, but they did before.
2) I pulled all fuses but the bottom red wire one with no help
3) The start button and power through the ignition test good.
4) When all fuses and key are in I get power on the left side of all but one of the fuses but also show grounds on almost all? That doesn't seem right...
5) Quite a few times my power is 12+v at the solenoid top bar, but once I try to start the tractor is drops to around 11v. But at the battery I still show 12+v.
I think that's all I got for now. Any help is appreciated.
Symptoms as of now:
