- Joined
- Nov 30, 2009
- Messages
- 9
- First name
- Keith C.
There is a hydraulic 'block' on the left side of my Zetor 8040 (directly above the a/c condenser) where there are 5 hydraulic connections on the top and two cable-like connections coming from the rear of the tractor. I have a significant hydraulic leak either at the front or back of this block. All of the connections on the top are tight...I couldn't be that lucky. I suspect there are gaskets or o-rings where the cables come in from the rear, or on the front elongated covers where the valves work back and forth. Does anyone know where I can get a parts schematic of this section of the hydraulic system so I can try to figure out what parts I need to order OR is there anyone that has experienced the same problem and can point me in the right direction? Thanks. Keith
