- Joined
- Oct 23, 2016
- Messages
- 1
- First name
- Jim Chalmers
The hydraulic lift arms on my 2012 Zetor Proxima 90 will not lower unless there is weight on them. When using implements this is not a problem because they have sufficient weight to lower arms. However when no implement is attached or when using the pick up hitch the arms wll not lower without a considerable weight being put on them. i.e. i have to stand on the arms to lower them.
I have checked all the control levers and they appesr to be working correctly. The tractor has been regularly serviced and has done approx 1000 hours.
