Right brake does nothing--is there a detailed disassembly procedure documented somewhere about how to remove the final drive and whatever else is involved to get in to the brakes?? Thanks
Thanks-guess I'm just too dumb to find it--I have looked many times and find nothing about the disassembly process..Guess all I can do is hope it is obvious once I start taking out bolts--surely there is info somewhere.............
I assume that the final drive(or whatever it is called-on each side) comes out still all together--I also assume that when the final drive/axle assembly comes out, the brake components come out with this assembly???
In simple terms. Support cab, disconnect pipe, slacken handbrake nuts, remove innermost ring of bolts, pull off complete assy with engine crane. Brake is easy to dismantle then.
