question 6745. When using PTO the PTO engage lever keeps slipping?
rohin
NSW, Australia
Rohin
6745 working tractor and a 6945 parts tractor
When slashing the PTO engage lever keeps slipping up or down at irregular intervals causing PTO to disengage. How to fix please?
It runs out of gear ?
There is a row of 5 bolts in front of the lever, these are hollow with a spring and ball inside. These cause the clicking you hear when you select a gear.
Either the most left one became undone, or the spring broke, so that it doesnt press the ball tight into the notch on the shifter rod, allowing the gear to wander.
Check that, and when in doubt, swap with another arrestor bolt to see if your problem persists.
Thankyou I will have a look. I have a parts tractor to replace things pretty easily.
It would be nice if you could complete your profile, e.g. add your tractors or where you come from. Thank you. :)
Profile updated.
I have looked at the bolt/spring and they seem ok. I will change over to another and see if it still occurs once I get going again.
