question Alternator replacement at Zetor 5911
ianyoung77
Sydney NSW, Australia
Ian
Hi Everyone,
My alternator died (saltwater) so I bought a Sparex replacement. It seems to fit ok but I don't know how to wire it or if it's externally or internally regulated. It has B+ and earth terminals which are obvious but then it has R and L. I'm guessing R is ignition and L is lamp if it's internally regulated. I've asked Sparex but no answer. Does anyone know?
please upload some pictures from the new alternator and the old one ... ;)
Here is the old and new alternator. The existing regulator seems to have a D+ and D- terminal plus each. But D- could be DF it's hard to tell
Here I have made a wiring diagram for this oldt type alternators without own regulator inside.
I think that should help to install it the corect way.
Generally, its better to use a alternator with integrated regulator - less parts, less wirings, easier install as you can see here:1727513413632.png
I made a new FAQ entry, with some more informations about this stuff around alternators in Zetor tractors...
Ta daa .... there it is:
