My PTO clutch would not engage. Crawled under and tightened the bolts on the adjuster by 1/2 of an inch or so. Clutch then engaged so I backed it off 1/8 inch to see if there was any difference. None detected... how does one ensure the adjustment is correct and the clutch isnt partially engaged?
open the haths on the left side of bellhouse and find the relesefingers for ptoclutch there should be 0-0,15mm clerense from the relesebearing.
Bjarne
