I replaced the thermostat housing and water pump. After the replacement, the upper pipe got really hot without the thermostat opening even after prolonged period. I ended up removing the thermostat and letting the coolant flow continuously into the radiator. This is summer so it seems OK, but I don't think this is normal. The thermostat is marked 78C. Any thought on what might be the problem?
