The tractor will NOT go forward when you let out the clutch it acts like it is in 5th gear high range with the brakes on and labors the engine down tell it quits or you push the clutch back in.I was doing some LIGHT disking only going down 4 or 5 inches deep just to open up the soil a little bit. Not working it very hard at all ,I had been going for a couple hours when I smelled something and saw some smoke coming up threw the floor next to the little plastic PTO shaft cover next to the 4 wheel drive shifter .So shut it down got out to see what was going on and saw lots of smoke coming out the hole on the left side of the tractor on the top of the rear differential about 6 inches in front of where the rod stick up to adjust the brakes.The only thing I can see that goes into the hole the smoke came out of was a small steel fluid line that threaded in right there.Left it it cool down for a couple hours and came back and started it up and went to go forward and it acted like it was in 5th gear high range with the brake on and lugged down the motor if you didn't press the clutch back in. So I made sure it was in low range first gear.Same thing lugged down the motor so I thought maybe the brake was stuck on So I tried reverse NO PROBLEM,tried high gear reverse NO PROBLEM.So I drove it back to the yard in reverse .I parked it on a small hill and let it roll forward and it did easily ,so the brakes are NOT stuck.I put it in both hi and then low range and tried all the forward gears and still acted like the brakes were on and it was in 5th gear range range type of thing and pulled the motor down.Can NOT find neutral on the main transmission.It goes into reverse and feels like it goes into all 5 forward gears but there is nowhere in there that it will go into neutral.So in all 5 forward gears positions it labors the motor down and will stall out if you don't press clutch in
Tried putting it in neutral on the high/low range shifter and it went into neutral their and so all that seems to be fine.
The engine is fine it would go up hills in reverse in both high and low range without pulling the motor down.
What is the steel fluid line that threads into that top opening on the differential that the smoke was coming out of and what is in that opening.
ANY SUGGESTIONS?????
THANKS
THANKS
