question Zetor Crystal 8045 hydraulic problem
Just to double check you have pushed the lever for hydraulics which on your right and closes to the seat, slide it all the way back towards the window and hold there to engage, now you should be able to hear the pump humming and also the engine will sound under pressure. you also see the hyd couplings vibrate on the back.
There is a flow control knob under the seat make sure it is not wound into the last it will stop the arm lifting.
where is the flow control know pic would be good
It's under the seat slightly to the right side, it's round and made of alloy. If t's all the way screwed in the lift arms are locked up and won't go down.
