zetro 5711
T
tomas
Guest
ola tengo un problema cn este tractor pero es q exa muxo humo por el tubo de escape a ver si alguien me puede decir q acer
I have a problem on my tractor where there is excessive smoke from the exhaust pipe. Can anyone help me?[/]
Tomas - what colour is the smoke?
Blue - worn oil rings on pistons or faulty valve seals
Black - overich mixture. incomplete combution/ Unburnt fuel . Injector or fuel pump.
White - fuel not being burned. Incorrect injection pump timing. Coolant getting into the combustion chamber can cause white smoke also. Possible causes are blown head gaskets, cracked heads cavitation, etc.
Tom
muchas gracias por la respuesta pero es q tiene muchas horas y tengo q reparar motor tmb tengo otro problema en la bomba q al subir a tope pega subidas y bajadas mui fuertes eso como se regula ai algun sitio?
Tomas - as this is an international forum, can you post your questions in English so that all members can understand them please?
My translation of your question is:
Your engine has many hours up (how many?) and that you may have a problem with the injector pump due to problems on hills/slopes.[/]
What colour is your smoke?
Will your tractor reduce its speed when going downhill or does it speed up when the the revs are reduced?
Tom
15000h y su primer motor yo no se ablarlo en ingles asik teneis q traducirlo vosotros
15,000 hours on the first engine is pretty good. Might te time to consider a rebuild. You may only have to do the top half of the engine.
Tom
