question Adding external lift control to Major 80
jawzx
MKW
So, I'm beginning the process of figuring out how to add an external 3pt lift control to my 2017 US market Major 80. I am pretty sure that this can be done, since the lift control already uses a cable linkage. It should be pretty easy to splice in a secondary lever for external control... But before I started I wanted to see if anyone else had done this before? If I can avoid reinventing the wheel I will... otherwise watch this space for updates...
So I guess you don't have buttons outside like on the Forterra do. Well our old 7340 only had a lever on the back came directly of the slider under the lever in the cab. But if yours works of a cable, there so many cable manufactures now you should able to get a dual control lever.
