My 6441 open cab is leaking brake fluid out of the top of the rear housing where the brake lines go in. Is there a replaceable seal or does this turn into a big job? I have not had any luck finding repair manuls on this tractor so hoping to get some help from you guys. I can bleed the brakes and they all work fine but you can feel the LH pedal not holding pressure due to the fluid comoing out on top of the rear axle housing. The RH side has a tiny little leak so I will problaly fix whatever the problem is on both sides.
