water capacity
fluffy57
fluffy
can someone help please had water leak on 6011 my fault drilled through water pipe up to heater i need to refill plus put antifreeze in any one know how much the system holds please :
Should be close to 14 litres with a heater if the system is completetly drained. Just remember to open the drain on the RH side of the engine block, as well as the one on the bottom of the radiator.
